All,
since I‘ve updated to 5.160.30, Zigbee devices directly included on the HC3 are no longer working properly. They don‘t react to triggers in scenes and when manually switched it either takes ages for them to react or not all all. All worked flawlessly for months with the previous HC3 firmware 🙁. Any advice? Cheers Alfons
Edited by awlieser
  • awlieser changed the title to Possible Bug: Zigbee Engine
There is some issues with the SDK which we are working thru with the Silabs responsible for it.
The simplest solution may be restoring the backup (not going back with the version, only configuration).
    Hi, m.roszak, thanks! Any idea when this issue might be resolved? Cheers Alfons
    It depends partially on us, most of the responsibility is on Silabs side.
    We have been fighting to resolve it for a few months now.
    If I will know something more, I will try to remember to put an update here.
    • Thanks 2
    No issues with my Zigbee devices after upgrade.
    Thanks!
    On this version, zigbbe worked until it lost power. I moved it to a backup to the previous version of zigbee and it worked again until it lost power - now nothing works anymore, what the... grrr
    I can confirm your observation, Had around 30 devices working and all dead after power loss
    • 6 months later...
    Are there any updates here?
    I just bought my first Zigbee devices and they do not react when embedded in some scenes.
    For instance, a hue bulb turns off in a simple scene, but I can't get it to turn on using the reverse scene.
    Direct control of the devices works very well.
