HC3 5.160.30 <> Google Home NOT working
I still have the same issue that I can’t connect my Google Home to my HC3,
I just upgraded to the latest version 5.160.30,
The only reply that I get from Fibaro / Yubii is “I have contacted the software department and the ticket was created.”
I'm getting super annoyed that I’m not getting any good response on this matter, it’s now +3 months since first reported.
Anyone else having this issue ?
Thanks, Kåre
Ticket number?
    I have opened so many topics on this issue and not getting any help,
    Ticket numbers:
    303438
    291043
    298453
    293302
    Hi, I have a procedure for when our installers encounter this issue. Many times it is a problem with the internet provider. To find out if this is the problem, simply create a Wi-Fi host with your cell phone with the SSID of the home Wi-Fi with the same password, turn off the home router (so that both the Google Home and the HC3 connect to the Wi-Fi host of the cell phone. ). After creating the WiFi hotspot, restart both the hc3 and Google Home and carry out the process of linking Fibaro with Google again.
    I hope it helps you.
    I followed the instructions but It's still not working,
    When I try to add Yubiii through Google Home I get the following messages:
    1) Yubii is linked
    2) Something went wrong. Try again
    I have exactly the same problem.
    The same problem for me:
    1) Connecting to a service FIBARO Smart Home...
    2) There is no connection with the FIBARO Smart home system.
    I finally got some help which fixed the issue,
    I just had to uninstall the google home app and reinstall it again, now it works just fine.
    Cheers, Kåre
    @kare yes we checked log and dont saw any communication from google to our servers for your account, so good that cleaning (reinstall) google apps helped
    Hi @kare, this is strange. I suppose you are using Google Home on iPhone, right? My primary device is Android, but the integration there does not work at all, but as the issue is the same not only fo Fibaro, I blame google for that. But when I tried clean Installation of Google Home on iPhone, I have the symptoms you had - first it says that it is connected, then "Something went wrong" follows...
    Never mind, all devices just appeared in Google Home. Strange...
    • 8 months later...
    I had the same issue. Upgrading to the latest stable version for HC3 and google home did the trick
