tzimber 3
Hi everyone,
So I was finally able to build my watering system.
I used a double switch (with 220V for its own power) and inputted 24V AC for a valve Slolonoied,
Everything is working fine, but I'm having a funny issue with the HC3 interface.
I have created 2 "Vaulve" devices each is linked to one of the dual switch ports, allowing me to control 2 vaulves.
So,
My goal is for example to get the "Trees" Vaulve 30 minutes of watering every other day, While the "Flowers" Vaulve works for 10 minutes every day.
Here is the thing,
under "Garden" I'm adding a new sequence, and choosing the "Trees" device.
I'm choosing the time and days for it to work.
So far, all is OK.
Now,
I'm adding a new sequence, let's call it "flower" 10
So what happening now, is that I can only choose days that I didn't choose in the first sequence.
days that were chosen on the first one are not clickable.
So yes, I can create another sequence for just the "Flowers" with the days that I didn't choose in the first sequence.
it's a bit of a workaround but ok.
But if tomorrow I want to create a new sequence that runs only on suddenly, for example, I can't do that.. as Sunday is already chosen in one of the other sequences.
What is behind the idea of choosing days just in one sequence?
