[SOLVED]5.160.30 - Error while backing up system configuration .... Reboot (with or without backup
Hello
Unfortunately I cannot upgrade my HC3 from to 5.150.18   to 5.160.30
When I try to install the update my HC3 (with or without backup box thicked)   ;  I have always the same issue = Error while backing up system configuration .... and a forced Reboot
Is there a manual upgrade  file available in order to do it from the recovery mode ?
Edited by daviddof
Please contact support, it does not work classically, from file it will be probably the same.
Share with me the ticket number as soon as you will get it.
    Hello
    Ticket open -number 303573
    updated with the help of the support with the recovery mode
