I have a paired a Aeotec siren 6 in HC2. I now have a couple of generic Z-wave device boxes representing different sounds, which I can play in the HC2.
I want my Doorbird intercom to make a remote http call to this url to play a scene that will play a sound (when doorbell is pressed) in this format http://user:password@ipaddresshc2/api/scenes/48/execute
I have made the user in hc2 for the doorbird to login with, but don't know what trigger to start the scene with in order to make the choosen sound play
please help
At what situation Aerotec should play a sound? When someone touch the ring on Doorbird (I hope so)? If correct, I think you do not need https call to activate. Instead you have to define an event called DBManualEvent and use it as a trigger to start any scene you wish (to use in in quickapps require little bit more knowledge). Events are defined via the webpage UI: configuration/general/events (I guess the names, my interface is in polish).
