Hello !
I post this message because after several installation attempts this update (that one and with the previous update (5.154) too), the fours CPU of the box are completely crazy 0% - 100% - 0% ... continuously.
So the box doesn't answer any more or with a lot of latency.
I had to do a recovery in the last version OK for me : 5.152.
I thought it was the Zigbee (I have 6 device).
So, I reseted all the Zigbee from the menu and try to re install the update, but same issue.
someone have any idea ?
Thanks for your help !
First time seen something like this - please contact support, they will check what is causing this.
    I did it...
    We will see...
    Any result on this issue?
    I have the same.
    @jjacques68 I asked the support team for the ticket but there is none created with your email.
    Could you share the ticket number with me?
    My ticket with the same symptoms: #306099
    @m.roszak, my ticket is #304027
    13 days ago, a technicien try to do the update (with remote access) without success.
    I don't have news since.
    I revived the subject 7 days ago...
    No response...
    I pushed this a bit :)
    today, a technicien try another time to make the update without succes.
    Same issue.
    CPU crazy ; freeze.
    I answered him on the ticket.
    it's starting to worry me... 😰
    Edited by jjacques68
    Last response from support :
    the problem is reported to the software departement...
    No more informations...
    @balageneral : have you news ?
    the support is connected again, today.
    The problem was with a QA which use the refreshState to send in a BDD the logs of the box (debug, trace, warning, error). (I want to save them)
    for a reason that I don't know, the logs are change after version 5.152, and a sort of loop without end crashed the box.
    I will try to do more analyse, but now, I don't save the log any more...
    thanks to the support !!
