In a Quick App UI, using several Slider Bars, I need to obtain the values of all Slider Bars to process the information, but I am not able to do so if it is not done one by one, through the onChanged event.
Would there be any way to access the values of the slider bars?
I've done a lot of research on the forum, I've done a lot of tests, but at best I managed not to generate an error and return an empty result 😁
Edited by Ilumyne
You should not treat the sliders as "variables" you can read.
Instead every time the slider change, update a table with the slider=value that you then store away (in a quickVar or GV)
Then you can at any time read the table for the latest values.
At startup you initialise the sliders and table to your start values.
    Hi, thanks for the feedback, I'll try to do it this way. Is it possible to work with vectors and data tables stored in variables?
