GTakacs 0
Hi All!
Today installed 3 pcs Roller Shutter 4 into a HC3L system. The module is good, the installation went perfect with the new push-in connectors.
BUT!
The module parameters show all of two buttons send the 1x,2x,3x press and the hold and release scenes to the scene controller. When I try to create a block scene I can select 3 (!!!) buttons of the scene controller and every buttons have only the 1x press, held, release events which I can select from the list.
What is wrong?
I updated the latest firmware of the modules (8.1) and the latest firmware of the HC3L. I use the Zwave Engine 2.
Has anyone same issue with this module?
Thank you!
