Hi
After the update all seemed well until i tried to use the keyfob and remotec. both dont trigger with my original scene.
Has there been a change to the 'CentralSceneEvent'?
No - no changes there. Could you share the code of the scene here?
    This is working now on 5.150 as i rolled back.
    When i updated it didnt work.
    I also have another client who experienced same issue too
    • 3 months later...
    I have the same problem with fw 5.161.15. on HC3.
    I also have problem to include zrc-90eu correct. After software reset i can get device included.
    I testet four devices and one of them is working on release, no other button is sensed.
    One refuse to include.
    The other is sensed as correct included but no button i sensed.
    Edited by EveWes
    ive got the scenes to work again.
    the triggers have changed.
    conditions = { {
    id = 251,
    isTrigger = true,
    operator = "anyValue",
    property = "centralSceneEvent",
    type = "device"
    operator = "all"
    I used blockscenes. I try to convert to Lua but history not show any action other than released on one of four devices.
    Is it possible that inclusion went wrong and device shows correct?
    Check your parameter settings as sometimes the presses need to be enabled
