Hi, we are a scout group and new users of Fibaro hc3l with 2 thermostats. The thermostats trigger two sets of heaters. We have created a climate schedule which has 4 degrees when we want no heat and 18 degrees when we want heat on. We really want a schedule that is fully off rather than 4 degrees. The climate has an off setting, but this just disables it all. Is there a way to schedule simple on/off rather than varying the temperature?
As far as i know, you can't do this using the built in climate dashboard.
