I red lots of feeds but I cant find one single, not complicate device wakeup script for HC3. Im not programmer but I can work with not complicated code..
I have this few lines from older threads in fibaro forum.
I have something like this:
%% autostart
%% globals
fibaro:getvalue(107, ´dead´)
to wake up:
fibaro:call(107, "wakeupdeaddevice"
OR
fibaro:wakeUpDeadDevice(
1071);
But I cant go through.. shows error (load):1: Assertion failed: Expected number
BUT HOW to get functional little script from these lines... THANK YOU very much for any idea.
Edited by MikeALL
format
Hi @MikeALL,
there is another thread where the "wake up dead device" function for a lua scene was described:
This is an example code to wake up the device with the device ID 10.
First check if the device is dead and if yes, then send a wakeup command.
local dev_id = 10
dead,_ = hub.get(tonumber(dev_id),"dead")
if dead then
    hub.call(tonumber(dev_id), "wakeUpDeadDevice")
  • 11 months later...
 This simple quickapp will attempt to wakeup HC3 dead devices every 1hr. You can upload attached file or use this code attached to a button:
