HC2 has only two LED on and not detectable in the local network
Hello guys,
My HC2 suddenly stopped working. It has the first 2 LEDs ON without any blinks. If I turn it off and on, then the rest of the LEDs will work, but then they will stop, and the first two will be ON all the time.
When I access my router network, I see it there, but with an empty IP address. Thus, I'm not able to access the recovery mode.
I changed the Ethernet cable and made sure it was not damaged, as it was working well with another device.
What could be the issue in this case?
Mustafa
looks like a global problem with HC2 - I have the same, HC2 stuck in "starting services"
