Regarding UNV uniview camera adding to Yubii Home
anyone here succeeded in adding IPC2125LE-ADF28KM-G camera to yubii home and share us setting followed and i tried most settings available here but nothing works.
i need someone helps to figure it out and get succeed in it.
Hi @Nadeem Mohammed ,
after adding camera to Yubii home did you check if it is visible with Yubii home app? Currently there is a problem with GUI interface and even camera is properly added it will not show camera stream in GUI. See this post:
    Hello.... yes you are correct on GUI interface its not showing any preview but its working on mobile application..
    it waste 2 3 hours just to troubleshoot issue.
    thanks for advise.
