Converting LUA Scene for Hc3 / Yubii, HELP!
calza
Hi all, I've tried chat gpt to make a lua script scene for my yubii home, previously 'ive made something on my HC2 with lua but i'm not that confident anymore...
Here's what i've got from chat gpt:
Yubii Home Lua Scene for Roller Shutter Control
This scene checks the status of two switches and adjusts the level of a roller shutter according to specific ranges.
-- IDs of the switches and roller shutter device
local switch1ID = 123 -- Replace with actual ID of switch 1
local switch2ID = 456 -- Replace with actual ID of switch 2
local rollerShutterID = 789 -- Replace with actual ID of the roller shutter
-- Function to get the current level of the roller shutter
local function getRollerShutterLevel()
return Yubii.getValue(rollerShutterID, "level")
-- Function to set the level of the roller shutter
local function setRollerShutterLevel(level)
Yubii.setValue(rollerShutterID, "level", level)
-- Main scene logic
local function main()
local switch1State = Yubii.getValue(switch1ID, "status")
local switch2State = Yubii.getValue(switch2ID, "status")
-- Check if either switch is turned on
if switch1State == "on" or switch2State == "on" then
local currentLevel = getRollerShutterLevel()
-- Adjust the level of the roller shutter based on its current level
if currentLevel >= 0 and currentLevel <= 9 then
setRollerShutterLevel(10)
elseif currentLevel >= 10 and currentLevel <= 49 then
setRollerShutterLevel(50)
elseif currentLevel >= 50 and currentLevel <= 98 then
setRollerShutterLevel(100)
elseif currentLevel >= 99 and currentLevel <= 100 then
setRollerShutterLevel(0)
-- Run the main logic
main()
Ok the scene look fine to my eyes, but i'm not able so save it in yubii...i see now lua editor is slightly different with condition and function separate... how should i make it work?
5 answers to this question
-- Main scene logic
main()
Not tested but should work.
Edited by Neo Andersson
  • no, it is not working =(
    I've put everything in the right column "actions" right?
    Tha final main() is useless now?
    This is in HC3 scene..this should work...
    Replace the switch IDs and shutter id to your
  • nope =(
    It is not getting the right value from the roller shutter...
    [ERROR] [SCENE82]: (load):16: attempt to compare number with nil
  • 14 minutes ago, calza said:
    Sorry, mistake in copying....it is working great!
    Thanks!!
