Dimmer 2 with Tesla Powerwall
Is anyone using a Fibaro Dimmer 2 with LED lights with a Tesla Powerwall.  I have an issue when the lights are dimmed and I take the Powerwall off grid on full battery mode the lights pulse (not flicker) from bright to dim.
Hopefully someone has a similar setup they can test this for me?
Many thanks
There's a bit of chatter on the interwebs on this issue, so you aren't the only one to experience it.  Also see
    Thank you I will take a look..
