I have installed this hotfix as in changelog it is stated that this is fixed. Unfortunately, both my Netatmo and Foscam cameras still are not shown on GUI, but are OK in mobile app.
Can you specify what is actually fixed for this:
"Fixed the problem of displaying preview from some IP cameras in web interface and mobile application. "
Thank you!
On my side,
4 caméra HIKVISION at home in the HC3 (latest firmware) , 1 is ok in the webinterface , 3 KO.
All OKs in the iphone app (hopefully)
Camera are not similar  (not the Model /  same resolution) but they are all configured in the same way (jpg not mpg)
Thank you!
There was a problem with the correct usage of the port for cameras in webUI.
We can check what else may be an issue if you will allow us to take a look at your system :)
PM me if you have some time to spare ;)
    I send you a PM :-)
