I would like to ask: lets's imagine we do
json.encode(table)
and use
setGlobalVariable(...)
to save it.
Next we restrore it by getGlobalVariable, then use json.decode(....) and assign result to the table again.
Would it be possible, that keys what in original table was numbers are converted (probably by json...?) to text after save and restore table?
I'm struggling with strange error in quite big QA and suspecting this.
json.encode(table)
and use
to save it.
Yes, don't use large numbers as keys.
{[200] = 'A'}
should be seen as a Lua array with 1-199 being nil.
However, the json.encoder trying to be helpful makes it a string key.
If what you encode is not what you get when you decode it's not really helpful...
    Thank you. The index was quite large - year number...
