@m.roszak
Can you please generate some events (start and end) in Fibaro to be able to start/stop the fan?
/monthly_2024_06/image.png.cd55656919b0f99bf5690e26102cf531.png" />
  • 1 month later...
    @m.roszak
    Any suggestion where to read the internal cpu temperature? Thanks
    I'm often having the same problem, while my HC3 is in open air no external heat or whatsoever.
    Same here. I'm thinking to place it in refrigerator, but then will have to see how to connect external antenna ;-)
    On 7/7/2024 at 8:31 PM, petrkl12 said:
    @m.roszak
    It is not available on the API at the moment.
    • 5 months later...
    Hi @m.roszak ,
    We are in the middle of the winter. My living room is heated to 22°C and my HC3 is placed on my desk far from any heat source and I just get this warning:
    /monthly_2025_01/Overheatingwarningmessage.png.4ceb902752aa7d7e0d3b7799f8b71b79.png" />
    I admit that I'm testing some QA. Have installed about 60 QA that will use to emulate z-wave devices included in my HC2, but they are all currently stopped (my code is not running). Other QA are just few of them with running code and the rest are all child devices.
    Another thing is that I have two browsers with web home page opened.
    I think it is good time to check this part of the gateway and improve. I know that this temperature is not available to users, but can you tell us at what temperature this warning is generated?
    I have similar problems in about 10 HC3. It's strange because HC3 at my office was changed thermopads about 2-3 years ago by Fibaro service and now I have the same problem.
    Please @m.roszak give us possibility to see the temperature and tell us what is the maksimum.
