Michal Sobczak 0
Hello, installed this Zigbee switch with only L and L1, no N wire. It works as a switch and it can be seen and added into Home Center 3. However after adding it does not work remotely and within few minutes it says that the switch become disconnected. Same thing with 3 times button press on the switch, it also shows that the Zigbee network is not connected. How is that? What can I do to make it work.
