Hi Fibaro,
Did any of the rescent updates changed the default value of the Virtual Thermostat (The one found under: Add devices ==> Other devices ==> Thermostat) properties "heatingThermostratSetpointCapabilitiesMax" to only 30 degree Celsius?
I noticed this when I had to update the selection of the temperature sensor and afterwards was no longer able to adjust it setpoint again at 36 degree Celsius. The thermostat that I didn't adjust still has a maximum of 82 degrees Celsius (not that I would like to set it so high). Also when I create a new one, it is also limited to the max 30 degree Celsius.
This eefects all my thermostaat that control the boilertemperature, since now I am only able to set the setpoint at maximum 30 degrees Celsius, which is not very comfortable when taking a warm shower.
Any adjustment / fix or command I could run to raise that maximum again?
And if the maximum allowed setpoint is indeed a concerning factor for a Thermostat, it would be good to at least have it as a optional parameter setting when building the virtual thermostat.
Regards and hoppefully you can direct me to a way to fix it, so everyone in the family can have a hot shower again,
Arjen
Edited by ArjenvM2
Changed title slightly
  • ArjenvM2 changed the title to heatingThermostratSetpointCapabilitiesMax set to 30 instead of higher?
Create and run a LUA scene with action part:
where device_id is the id of your thermostat device
