loganizzi 0
I've been searching the forum and google but only getting myself more confused since much of the information I found refers to UK and 2 wire installations.
I have a newly wired house with several rooms configured with LED wafer ceiling lights controlled by toggle switches from 3 different locations. I'd like to install a dimmer 2 to control dimming using the original toggle switches (antique retro style button i.e. -
).The wiring configuration is similar to this:
/monthly_2024_07/image.png.cd2e6bad90bd6c15e2dbea2395f11c9f.png" />Can someone help me understand how I would wire the Fibaro Dimmer 2 into this configuration?
I expect to be able to dim only using the app but be able to turn on/off the lights from any physical location.
Thank you
Edited by loganizzi2 answers to this question
