petro_cz 32
Hi I have two ZMNHVD1 with temperature sensor and neither one installs so that the thermometer is visible, the sensor is connected when the device is added to the network. They both do the same problem. I have a zwave HC3 in motor 2 mode. When I tried on engine 3, the sensor is found but does not change temperature. Who has this device and can help me activate this feature? Thank you
4 answers to this question
