MauriceS 0
At this moment I have a smart meter connected to a Veraplus. With the LUA code I've added, I can read the power consumption in my HC2. Today I upgraded from a HC2 to a HC3.
Now the Lua code won't work anymore. I'm not into Lua yet so please could anyone help me with this problem.
Thanks in advance!!!!!
%% globals
fiveMinuteTimer
local selfId = fibaro:getSelfId();
HC2 = Net.FHttp("xxx.xxx.x.xxx",3480)
response,status = HC2:GET("/data_request?id=variableget&DeviceNum=383&serviceId=urn:micasaverde-com:serviceId:EnergyMetering1&Variable=Watts")
fibaro:call(202, "setProperty", "ui.Label2.value", response)
fibaro:debug(response)
fibaro:log(response)
response,status = HC2:GET("/data_request?id=variableget&DeviceNum=384&serviceId=urn:micasaverde-com:serviceId:EnergyMetering1&Variable=Watts")
fibaro:call(202, "setProperty", "ui.Label3.value", response)
response,status = HC2:GET("/data_request?id=variableget&DeviceNum=385&serviceId=urn:micasaverde-com:serviceId:EnergyMetering1&Variable=Watts")
fibaro:call(202, "setProperty", "ui.Label4.value", response)
myVariable = (fibaro:getValue(202, "ui.Label2.value")) + (fibaro:getValue(202, "ui.Label3.value")) + (fibaro:getValue(202, "ui.Label4.value"))
fibaro:debug('myVariable is value is:') --prints value of variable
fibaro:call(202, "setProperty", "ui.Label1.value", myVariable)
fibaro:debug(myVariable)
fibaro:log(myVariable)
