strijkje 0
Hi Guys,
Tldr:
We want the ability to control the lights from the hall ways 1st, 2nd, 3th, 4th floor with light switches on each floor.
But do i understand it correct that a fibaro relay switch can only be controlled with 2 switches?
I found this
, that makes me think it is possible?If i understand it correctly, it acutally means that it is not needed to place a relay behind every switch, but before every light?
also can i use the second switch of a fibaro double switch 2 as a virtual button?
So i don't connect a cable to it, but if i press it, a light goes out (that i configured in homey)?
Long story:
I'm currently starting to cable my new home.
I want to make it (in the future) a smart home.
Given the budget, i would wanne start with a "dumb"/classic house, with a few things that are smart from the beginning (windows shades, few lights smart).
However, the plan is to gradually make the house completly smart.
The things we would want to achieve at "the end" is:
But we want to start with a dumb house and the ability to use the house when the smart things are down (and the ability to resell the house)
The plan is to connect every light with the fuse box with a 5g1,5 cable (5 cables in one tube) and every light switch with a 5g1,5 (i assume that the term 5g1,5 isn't used everywhere in the world).
This way we can install dumb switches (from the brand Niko), given the fact that there are 5 cables to each switch means that i can route the "signal" back to the fuse box and connect the right switch to the right lights in te fuse box.
Somethign like my sketch (the blue is the fusebox, yellow the ligth and gray the switch)
I found the fibaro switches and dimmers, and it seems like they can do what i want.
I want to connect them to a Homey pro hub.
There is only 1 thing i'm not sure about.
I found this
If you guys have any other tips/suggestion, i'm happy to hear them!
Thanks in advance
Edited by strijkje5 answers to this question
