Block scenes doesnt run on HomeCenter 3.
Trying to get block scenes to trigger if motion sensor or binary sensor are triggered and then turn on some lights. But I cant seem to get any working. Have tried with several devices. What am I doing wrong?
Edited by Sbr77
5 answers to this question
Without providing us what did you actually do, it is hard to help. Give me some screenshots about your scene.
But the first thing that comes to my mind, didn't you forget to tick the trigger checkbox?
/monthly_2024_07/image.png.5d947d8d79e53653fa889832b9386ad1.png" />
    Use as trigger is ticked. Having problems attaching files at the moment.
    Cant add files, server error. So here´s the LUA code.
      conditions = { {
          id = 155,
          isTrigger = true,
          operator = "==",
          property = "value",
          type = "device",
          value = true
      operator = "all"
    ACTIONS
    hub.call(53, 'turnOn')
    @Neo Andersson Any tips you can share why this isnt working?
    1. What type is the motion sensor of?
    2. Can you see in logs, or in History panel, that when sensor is breached, there is an event tirggered?
    If not something's wrong with the sensor, or its parameters.
    3. What type is device 53?
    Can you see in logs or in history when the sensro breaches, there is an actiion called to the device 53?
    If not something's wrong with device or its parameters.
    4. Try separately check if you stand infront of the sensor, does it trigger the event?
    5. Try separatelly check if device can be truned on by button press, or by calling from LUA?
    6. Is your scene activated?
    Give me  a screenshot of the entire block scene. (not LUA)
    Edited by Neo Andersson
    Reconfigure of the sensor did the trick this time even though I already tried that several times before. ....
