Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. New device control views
    A new way of controlling all device types from the Dashboard and preview in device settings for a better user experience.
2. Advanced user
    Introduction of a new type of user in the system with configurable access to system settings.
    From now on, the administrator can decide which parts of the configuration interface will be accessible to users who are not system owners.
3. Gateway Connection with Z-Wave Engine 3.0
    Systems using the new Z-Wave engine can now use the Gateway Connection feature.
What's new:
Access
New UI for configuring access settings for normal users.
Alarm
By default, triggering an alarm will now result in sending a Critical Push (iOS) and Push (Android) for the new Yubii Home app.
Climate
A new way of direct zone control from the climate dashboard.
Dashboard
Adjusted icon sizes for better visibility.
Devices
Support for the dark theme for the new binding wizards in the mobile application.
Updated and added new binding instructions to the binding wizards.
Support for FGDW-002 in version 3.3 added.
Updated some parameter templates for various supported devices.
Minor UI/UX improvements in the binding wizards.
Improvements in Linked Devices (blinds).
Calibration of devices now available in advanced device settings.
FGT-001 external sensor temperature offset setting removed.
Gateway Connection
From now on, the upper limit for allowed slave hubs is set to 15.
Nice*
Added support for 2nd favorite position for Nice screens and blinds.
Other
From now on, restoring a backup or switching the system won't disable Remote Access for support if it was enabled before the procedure.
Plugins
WakeOnLan plugin UI fixes.
Improvements in Nice Cameras plugin for better streaming performance.
Quick Apps
Added the possibility to set custom views for child devices.
Added the possibility to copy view definitions to the clipboard (works with HTTPS connections only).
Added the possibility to add custom view elements to thermostat views.
Improved webview performance.
Scenes
Support for the dark theme for Simple Scenarios.
The Sound Switch device type added to Simple Scenarios.
Z-Wave
User Code command class support added.**
Simple AV Control command class support added.**
Inclusion and configuration of supported devices performance improvements.**
Added support for numerous old-gen devices (ZW300, ZW500 series).**
Disabled blur on the Z-Wave console during the device-adding procedure.
Disabling the Security S0 adding mode available.**
Zigbee
Improved performance for executing bulk actions.
Improved device availability-check module (marking devices as not reachable).
Support for MOES Human Presence Sensor ZSS-QY-HP added.
Bug Fixes:
Backup
Fixed rare error during backup restoration.
Cameras
Fixed camera previews in some cases.
Devices
Fixed default icons for some device types.
Toggle action support fixed for the multiposition switch device type.
Fixed incorrect message when performing calibration of FGD-221 device.**
Fixed setpoint graph for FGT-001, which was not correctly shown in some cases.
Unable to add device in Security S2 if the PIN was incorrect (out of allowed range).**
Minor UI fixes in FGR-224/Roll-Control 2 advanced settings.
Refreshing advanced parameter values in the wizard binding procedure did not work correctly.
Fixed setting favorite positions for some blinds.
Gateway Connection
Fixed issue with special characters in passwords for the slave hubs.
Update visibility for slave hub did not work correctly.
History
Some duplicated events removed.
Nice*
Fixed support for MHouse protocol gates with new hardware revision.
BiDi-Multisensor is temporarily marked as disconnected when resetting some device parameters to default.
Notifications
Redundant intervals removed from the configuration page for event-type notifications.
Other
Minor translation fixes.
Minor UI/UX fixes.
User is logged out from the system after creating a backup.
Quick Apps
Added QuickApp is placed in the incorrect room in some cases.
Recovery
Fixed issue with updating the hub from Recovery from 5.140 to 5.153 Beta.
Fixed issue with checking system version when using the Repair option.
Rooms
Fixed issue with setting the default room icon after removing a custom icon from the system.
Cannot remove custom SVG icon in room settings.
Custom room icon is not visible when editing the room settings.
Scenes
When a new scene is added, the window does not scroll to the newly added element.
Possibility to type too long a name for Simple Scenario, which blocks the possibility to save it.
Lack of some scene icons after system restart in rare cases.
Small UI fixes in Simple Scenarios.
Main Z-Wave devices available in block scenes device selector.
Fixed issue with Scene Activation feature in block scenes.
Swapped triggering the scene on Doorlock state.
Update
Download progress bar visibility depends on the checkbox selection (beta).
Z-Wave
Error 500 in some rare cases during the Z-Wave device reconfiguration process.
Requesting Neighbors update action not always triggers correctly.
Fixed setting the device polling interval manually.
BiDi-Zwave device is added with a wrong system role by default.
Qubino 0-10V Dimmer parameters are being restored to default during inclusion.
Zigbee
Device removal procedure fixed.
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
