Quickapp works except labels are not being updated after update to Beta
I have just updated to the latest Beta and noticed that a QA I wrote is not functioning at 100%. The QA communicates with the device OK and the buttons work correctly however the labels do not update with the required detail.
The question mark tool tip indicates that "HTTPS connection is required for this function to work" however the link to my receiver does not require a login.
Any thoughts as to how this can be ressolved?
Thanks,
Anthony
If you would like to use html tags in QA you need to use the "old" view for displaying the content of the QuickApp.
/monthly_2024_07/image.png.595316ff710cef74182515f9e7e61c08.png" />
Make sure to check it on the actual view on the Dashboard.
We got some issues with refreshing some of the content at the moment (it is linked with buttons visibility changed on the fly from the code) but it should work for labels.
    Ah! Thanks very much!
