Hi, I am creating a QA to make logs of wind sensor available in the yubii apps (maybe lux, temp, humidity too later)
QA:
I am now updating my label like this from the info.timestamp table and info.value table.
but I have to make a line for each value i want to show.
any1 knows if it is possible to update depending on how many values i get from my api call  ?
and sometimes i get less then 10 values back ill get an error too so 😅Any suggestions on how too do it?
function QuickApp:update()
local function fmt(v)
      val = string.format("%02d",v)
      return val
local fromtime = ""..self.store.year.."-"..fmt(self.store.frommonth).."-"..fmt(self.store.fromday).."-"..fmt(self.store.fromhour)..""
print("fromtime: ",fromtime)
local fromtime2 = toEpoc(fromtime)
print("fromtime2: ",fromtime2)
local tootime = ""..self.store.year.."-"..fmt(self.store.toomonth).."-"..fmt(self.store.tooday).."-"..fmt(self.store.toohour)..""
print("tootime: ",tootime)
local tootime2 = toEpoc(tootime)
print("tootime2: ",tootime2)
local data = api.get("/events/history?eventType=DevicePropertyUpdatedEvent&from="..fromtime2.."&to="..tootime2.."&objectType=device&objectId="..sensorid.."&numberOfRecords="..self.store.records.."")
for _,d in ipairs(data) do
info.timestamp[_] = todate(d.timestamp)
info.value[_] = d.data.newValue
--print("info.time:",info.timestamp[_], "info.value",info.value[_])
local line1 = "<font color=Green>Chart with timestamp and "..unittype.." in <font color=green>"..unit.." :"
local line2 = "<font color=orange>"..info.timestamp[1].." "..unittype.." <font color=green>"..info.value[1].." "..unit..""
local line3 = "<font color=orange>"..info.timestamp[2].." "..unittype.." <font color=green>"..info.value[2].." "..unit..""
local line4 = "<font color=orange>"..info.timestamp[3].." "..unittype.." <font color=green>"..info.value[3].." "..unit..""
local line5 = "<font color=orange>"..info.timestamp[4].." "..unittype.." <font color=green>"..info.value[4].." "..unit..""
local line6 = "<font color=orange>"..info.timestamp[5].." "..unittype.." <font color=green>"..info.value[5].." "..unit..""
local line7 = "<font color=orange>"..info.timestamp[6].." "..unittype.." <font color=green>"..info.value[6].." "..unit..""
local line8 = "<font color=orange>"..info.timestamp[7].." "..unittype.." <font color=green>"..info.value[7].." "..unit..""
local line9 = "<font color=orange>"..info.timestamp[8].." "..unittype.." <font color=green>"..info.value[8].." "..unit..""
local line10 = "<font color=orange>"..info.timestamp[9].." "..unittype.." <font color=green>"..info.value[9].." "..unit..""
local line11 = "<font color=orange>"..info.timestamp[10].." "..unittype.." <font color=green>"..info.value[10].." "..unit..""
self:updateView("loginfo","text","<table width= 400px border = 0px><td align =left><section align='left'><font size='"..Fontsize.."'><tt> "..line1.."\n"..line2.."\n"..line3.."\n"..line4.."\n"..line5.."\n"..line6.."\n"..line7.."\n"..line8.."\n"..line9.."\n"..line10.."  </tt></font></section>")
sensorvalue = string.format("%.0f",hub.getValue(sensorid, "value"))
self:updateProperty("value", hub.getValue(sensorid, "value"))
self:updateProperty("log", ""..unittype..":"..sensorvalue..""..unit.."")
Edited by Brors94
You already have the loop
Make a variable within the loop with the wanted text and data like:
labelText = “”
labelText = labelText ..”text: ” ..variable ..”\n”
and insert the variable labelText in your label.
Edited by SmartHomeEddy
    @SmartHomeEddy Thanks!! 😄 Makes it alot cleaner and was way to easy when you gave me the direction 😅
    @SmartHomeEddy may i ask about 1 more thing?
    edit:  (my braint didnt work😅
    This was a solution 😄
    rownumber =  1 + rownumber
    line = ""..line.." \n<font color=orange> "..rownumber..":"..info.timestamp[_].." "..unittype.." <font color=green>"..info.value[_].." "..unit.."   "
    Updated QA:
    If I want to add the "Row number" to the label how do i do that in the loop?
    this throws an error
    line = ""
    rownumber = [_]
    Edited by Brors94
