Devolo Danfoss Thermostat, Water sensors, Door contacts, pls help!
i have Home Center 3 and a lot of Devolo Thermostats (09356) MT02650 in the house.
The connection works perfectly but I can't change the temperature, nothing. What am I doing wrong, why can't I control the thermostats properly?
Thanks a lot, I am a Beginner
Edited by DjGreg7
    did you know if i can get my devolo water sensors and door contacts and siren to work?
    I have similar issue with Devolo and Keemple Danfoss LC-13. They work fine, however I cannot change temperature from iOS Yubi app. There is only a time to be set, no temp. The scheduler however works and changes settings on thermostats. I am on HCL3, Z-Wave 3, latest stable firmware.
