HomeKit not see sensor
Hello, I installed the door and window sensor FGBHDW-002. With the "FibaroHome" app connected to the home Wi-Fi I can check if the door is open or closed, temperature and battery status. Now I wanted to add a HomePod mini as a home hub. The HomePod mini has installed and connected, but the sensor is not "visible" on the home app (accessory is unresponsive). How can I fix it? Thank you
