fibaro door sensor firmware
Yes, there is. Why ask, isn't the update in your dashboard?
Quote
ATTENTION! IMPORTANT INFORMATION ON THE SOFTWARE UPDATE!
In order to properly update the software, IT IS NECESSARY THAT THE USER ENSURE ALL THE CONDITIONS AS FOLLOWS, during the whole update process:
1) continuous and uninterrupted power supply to the device where the update takes place, by current supply (continuous and uninterrupted power supply without voltage/current changes by more than 10% from the standard voltage/current in the country where the device is used) or by the battery (fully loaded);
2) continuous and uninterrupted Internet access;
3) maximum reduction of the data traffic in the Z-Wave network where the update takes place, it is the maximum reduction of use of the devices in this network (including the data traffic resulted from the direct use of the devices as well as the data traffic resulted from the scenes and associations);
4) continuous and uninterrupted physical presence of the User in the building where the devices with the updated software are installed, in order to ensure the proper operating condition of the device and the update process.
The above indicated conditions do not depend on the Producer.
In the event of not ensuring by the User any of the above indicated conditions THE SOFTWARE UPDATE MAY RESULT IN AN IRREPARABLE DAMAGE TO THE DEVICE OR TO THE MODULE OF THE DEVICE, and in particular in failure in scenes’ functioning.
The Producer DOES NOT ISSUE ANY WARRANTY WHATSOEVER for devices’ defects resulting from the failure of ensuring any of the above indicated conditions by the User. The devices are subject to the usual Producer warranty during this Producer warranty period as well as to the implied by law warranty during this warranty period.
By accepting this statement you accept all the risks as above indicated.
The Producer informs that SOFTWARE UPDATE IS NOT NECESSARY for the continued proper functioning of the device.
STATEMENT NO 2
ATTENTION!
The Producer informs that the process of software update may result in consequences as follows:
1) necessity of re-introduction of the group associations in the device where the software update took place and/or
2) necessity of reconfiguration of the device where the software update took place.
Failure to perform the operations as above indicated may result in non-functioning or malfunctioning of the device where the software update took place.
Changelog 3.3
Improved battery level reporting.
Fixed battery report showing 0% when using the batteries that came with the device.
Warning:
Update can take up to 30 minutes. It depends on Z-wave traffic.
Wait few minutes after successful update and check if version of device has changed.
There may be need of re-introduction of the group associations in the device where the software update took place.
In case of strange device behaviour there may be need of reconfiguration/reinclusion.
Yesterday I added 2 new Door/Window Sensors. Both with firmware 3.2. Only one of them gave an 3.3 update. All the other (older) Door/Window Sensor had an update available.
After updating all to 3.3, and because off the adding of the 2 new sensors with some scene's, I did a Back-Up of the controller.
Only after the Back_Up  and start-up of the controller, the last 3.3 firmware of the Door/Window sensor popped up.
So maybe a reboot may work. And of course a working internet connection. 🙂.
Edited by Flash
