ERROR in LuaEnvironment while using net.HTTPClient()
Hello.
This is not a code issue, the code is only included for reference, please move this question if i have posted in the wrong place, if that is the case.
I get this sporadic error and this stops the scene.
It happens around 3-4 times a day.
I never get any other faults (in debug), so the connections to Internet is solid.
So, the question, is this a HC2 firmware issue?
HC2 Firmware is 4.620.
[ERROR] 08:17:04: LuaEnvironment: /opt/atlassian/bamboo-agent/xml-data/build-dir/NHC2-NHCLUAENG65-JOB1/LuaEngine/vendor/avhttp/avhttp/impl/http_stream.ipp:2269: void avhttp::http_stream::handle_skip_crlf(const MutableBufferSequence&, Handler, boost::shared_array, const boost::system::error_code&, std::size_t) [with MutableBufferSequence = boost::asio::mutable_buffers_1; Handler = boost::function; std::size_t = unsigned int]: Assertion `crlf[0] == '\r' && crlf[1] == '\n'' failed.
AI says its:
"This error is caused by an assertion failure in the handle_skip_crlf function of the http_stream class in the avhttp library."
Reference code:
Edited by speedy
Clarity.
