Poely 0
I have a RGBW controler. When i turn on the light, sometimes nothing happens.
I think i figered out why. When i turn it on, the status is on, but default de RGBW is all 0.
When i change the warm white to a value and put brightness to 0 and back to a value like 50 it turns on.
When i switch the RGBW off and on again, it is fine. But after a power failure or something the same issue happens.
So i tried to change the default parameters for RGBW and Brightness. But parameter 1 is visable, 2 till 29 missing.
First thing i did was reboting, nothing happens.
Firmware is up to date (HC3 and RGBW controler).
Then i looked and found topics that the parameters should be in Advanced.
But the parameters are not visible under advanced.
I pressed reconfigure and also read configuration, no result.
Ik looked in all the family devices, nowhere to find.
See the screenshots
/monthly_2024_08/image.png.60c0c0518a825aadeabf8757fafbfc40.png" />Please login or register to see this attachment.
