Hello guys
We are offering for sale these really helpful boards for fibaro implants.
This board allows installers to install Fibaro Implant modules more cleanly and easily.
Normally with the included Implant wire, an installation looks very messy as you have to splice the wires together. This is OK for small items which don't have a lot of space, but for use cases like garage doors, gates etc... a screw terminals are much better. They are also better for diagnosing problems, as a multimeter probe can be used to measure the contacts.
The board can be mounted on a DIN rail as well by adding a simple plastic DIN rail holder.
The board includes screw terminals for all inputs, it also includes 2 bigger relays (either 12 or 24V) which are the most common ones used. These relays can switch up to 10A. The relays have NO/NC contacts.
We use this board for almost all installations as it much cleaner then a box of wires if we were to use the original Fibaro wire, plus with the benefit of the relay we can switch much bigger loads (we mostly use them for electric locks).
Price 20 eur netto / pcs
In case of larger order the price is open
/monthly_2024_08/WhatsAppImage2024-08-21at09_46.21_2469d0e6.jpg.69f878523f639485153b9c56f6fd62f0.jpg" />
In case of interest please send me a PM or write to [email protected] mail address
@Neo Andersson Great job!  Does your board come with the little Fibaro wiring harness, or must this be soldered on by the user?
Hello @Tim__ I work with @Neo Andersson I designed those boards.
The board includes a brand new cable, that connects the implant directly to the PCB. The relay contacts are connected via the exposed "pins" so no soldering is needed :).
