nea 3
Hi. I'm looking for a solution where you can turn on/off the display of the Heatit Z-TRM6 via HC3. Even with the lowest brightness settings, it is annoying in a dark bedroom. It is possible to turn off the display completeley manually on the device. However, I can not find any parameter for this in the template in HC3 and the parameter is not described in the manual either.
Taken from the
:22.DISPLAY ON/OFF (DON/DOFF) The thermostat has a display ON/OFF function which decides whether the display should turn completely off when in Standby. To enable/disable this function, hold the Left and Center buttons for 10 seconds. The display will show “DOFF” when the function is activated and “DON” when the function is disabled. When operating any button, the display will light up.
It would be nice to make the display follow the rest of the light settings in the room. Anyone solved this?
