Brors94 115
I am thinking off makeing a "Room Controller QuickApp" for easy setup or change of motion sensor, lux sensor and diffrent "scenes/light levels" Depending on profiles.
So if you got a new installation it is just to upload the QuickApp, set quickapp variabels for motion sensor, lux sensor and room id if you want.
I also gets the status of the pir and lux sensor. And can set the normal delay (5sec - to 20min adjustable with 2 buttons).
for now the quickapp when it starts it load, all the light (color, multilevel and relays) in the room the controller stands inn, but also possible to set a Quickapp variabel to set the room id it should get the lights from.
I am thinking of makeing it possible to setup 6 custom scenes, 2 for standard on/off and 1 custom lux adaptive scene and 2 scenes for fade on/off with timers. (slow fade from last level to off/on over 60sec for exampel)
to adjust the scene just set the lights in the room like you want it, then open the Quickapp and hit "Save scene1".
This scenes can then be choosen to be triggered when:
And first I am making it to support 4 Profiles. ( you can then set all the events above for each profile)
But I havent figured out the best way to make it adaptive to the Lux level 🤔
I am thinking of making a check every 30min for the lux level and set 10 points that can be manuali changed to represent when the light should be 10%-20%-30%-->100% based on the lux level.
any1 got a suggestion on how to do it? 😄
and am I missing some functionality that should been in a Quickapp for light control? 🤔
/monthly_2024_08/image.png.bcb3bc0e48f79a8b5d29a921c257c804.png" />And the reason everything is placed to the left, is because my thumb is to big to scroll down without tutching button otherwise 😅😆
