Hello @m.roszak, @K.Drozynski,
New mobile app would be much better if you could avoid showing double information or unnecessary information (repeating room name on all devices?):
Or when QA is expanded:
Is it really necessary to have value shown on two places? Also what that "Value" is doing bellow value? Also that triangle above value shows nothing since probably we need to set at least maximum value so that can be filled depending on current value.
As you can see I had to put green circle to the 'unit' because log is not shown on QA in app. Also, lots of empty space in the body.
QUESTION: Is there any chance that you will improve QA display on Yubii Home app and add place to show logs?
I would like if open menu >> other
you can see alarm is activated for example green >>> armed and red >> alarm. So you don't need to click alarm to see the state
power is both in value and "power" property as you got power interface added?
Thats why its duplicated in general.
"power" interface and property for actors, com.fibaro.powerMeter device type and value for meters reporting power.
If you correct this, it won't be duplicated anymore.
About the room name, we will discuss this.
    Hi @m.roszak ,
    thanks for considering it. On HC2 virtual devices didn't show room and I never missed it.
    Please consider adding QA log field to be shown in mobile app, then I will not have to use UNIT to add additional information. PLEASE, PLEASE, PLEASE ADD IT! THANKS!
    • Thanks 2
    Yep, for me to. Added in all kinds of quickapps information in the log text and now it is kind of gone.
    16 hours ago, Sankotronic said:
    Hi @m.roszak ,
    It's already reported to be fixed, 2.3 should have it.
    • Thanks 3
    • 1 year later...
    On 2/21/2023 at 5:08 PM, iTibor said:
    Hi
    Did you manage to write the QuickApp?
    On 9/11/2024 at 10:36 PM, Sankotronic said:
    Hi @m.roszak ,
    Still no log on quickapps?
    2.5.1 fixes that, should be available very soon.
