I'm trying to write QA to Gardena. Using the API, I get a token that is needed for authorization,
then using this token I try to get information about the location but I get a 403.
Doing the same (using the same token), e.g. in the Postman application, gets the data I need. Can anyone tell me what I'm doing wrong?
My code
APi documentation
Maybe use the token in the authorization, like
    Maybe the headers from anwer will help.
    Does anyone know if the home center sends http request directly or through some Fibaro servers?
    Even from ios shortcuts it works
    /monthly_2024_09/image.png.0f350497463daa04c9d0dd3f3ea638f4.png" />
    Edited by marczu_83
    • 8 months later...
    any update on this dev ? i am trying todo the same thing and i do have some code ready that catches the refresh token but then indeed to go further it does nothing so also seeking some help.
    I don't remember what exactly caused the problem, but something on the DNS side, I used pihole, or adguard. I'm currently connecting to the gardena API, everything works fine
    @marczu_83 would you mind sharing your code ? i can also share mine if you want already, i believe many are waiting on a quickapp that works for gardena :-)
    Currently i have a quickapp where you can fill in all your info and it gets you the token but i am a bit stuck since that is where it stops and does not proceed with the next command i give it.
    • 3 weeks later...
    @marczu_83
    this is what i got untill now and it does get the token.
    i am now searching how to use the token and go towards the location data so i can then retrieve the data.
    -- Generic device type have no default actions to handle
    -- To update controls you can use method self:updateView(<component ID>, <component property>, <desired value>). Eg:
    -- self:updateView("slider", "value", "55")
    -- self:updateView("button1", "text", "MUTE")
    -- self:updateView("label", "text", "TURNED ON")
    -- This is QuickApp inital method. It is called right after your QuickApp starts (after each save or on gateway startup).
    -- Here you can set some default values, setup http connection or get QuickApp variables.
    -- To learn more, please visit:
    function QuickApp:onInit()
        self:debug("QuickApp: onInit")
        self.username       = self:getVariable("username")
        self.password       = self:getVariable("password")
        self.client_id      = self:getVariable("client_id")
        self.client_secret  = self:getVariable("client_secret")
        self.refresh        = 3000   -- refresh time in seconds
    -- Main loop
        self:loop(self.refresh)
    function QuickApp:loop(refresh)
        self:oAuthGardena(function(token)
            --self:getGardenadevicedata(token)
        end)
        fibaro.setTimeout(refresh * 1000, function()
            self:loop(refresh)
        end)
    -- 1 Variables Check & Tokenrequest
    function QuickApp:oAuthGardena(func)
     local request_body = "grant_type=client_credentials&client_id="..self.client_id.."&client_secret="..self.client_secret
        if (self.username == "" or self.password == "" or self.client_id == "" or self.client_secret == "" or
            self.username == "-" or self.password == "-" or self.client_id == "-" or self.client_secret == "-") then
            self:error ("Credentials data is empty!")
            self:updateView("status", "text", "Credentials data is empty!")
            return 0
        self:getGardenaResponseData("https://api.authentication.husqvarnagroup.dev/v1/oauth2/token", request_body,
            function(data)
                if (data.access_token ~= nil) then
                    self:debug("Gardena-oAuth ok, Token: "..data.access_token)
                    self:debug("Gardena-oAuth Tokentype: "..data.token_type)
                    self:debug("Gardena-oAuth Expires in: "..data.expires_in)
                    self:debug("Gardena-oAuth Provider: "..data.provider)
                    self:debug("Gardena-oAuth Userid: "..data.user_id)
                    func(data.access_token)
                else
                    self:error("Can't get token")
    function QuickApp:getGardenaResponseData(url, body, func)
        --self:debug("HTTP url: "..url.."; body: "..body)
        local http = net.HTTPClient()
        http:request(url, {
            options = {
                checkCertificate = true,
                method = "POST",
                headers = {
                    ['Content-Type'] = "application/x-www-form-urlencoded;charset=UTF-8"
                data = body
            success = function(response)
                if (response.status == 200) then
                    -- self:debug("Response: "..json.encode(response))
                    func(json.decode(response.data))
                else
                    self:error("Wrong status '"..response.status.."' in response!")
            end,
            error = function(message)
                self:error("Connection error: " .. message)
    -- Getting Data based on one request
    @marczu_83
    how do you update the value
    here i am still stuck on that so the next request does not do anything.
    also when trying todo the second HTTP request it starts mixing them, not really following the code to be honest.
    could you post the complete code so i can learn ?
    here is what i have for the moment.
     self:debug("QuickApp: Starting")
     self.Location_id    = self:setVariable("Location_id", "")
    --- MAIN LOOP
        self:CheckFields(function(CheckFields)
        end)
        self:GetGardenaToken(function(GetGardenaToken)
        end)
        self:GetGardenaLocations(function(GetGardenaLocations)
        end)
        fibaro.setTimeout(refresh * 3000, function()
            self:loop(refresh)
        end)
    --- CHECKING IF ALL INFORMATION IF FILLED IN
    function QuickApp:CheckFields()
    self:debug("Quickapp: Checking Info Fields")
            return 0
            else print("Getting Token")
    --- GET GARDENA TOKEN
    function QuickApp:GetGardenaToken()
    self:debug("Quickapp: Sending request for token")
         http:request("https://api.authentication.husqvarnagroup.dev/v1/oauth2/token", {
          options = {
            method = "POST",
            headers = {
            data = request_body
            local data = json.decode(response.data)
            self:debug(data.scope)
            Token = data.access_token
            --setInterval(function() self:renewToken() end,1000*3600) -- Renew token every hour
            print("Status", response.status)
            print("Data", response.data)
          end,
            self:error("error:", message)
    function QuickApp:GetGardenaLocations()
        if self.Location_id == nil then
            -- local url = self.smart_host.."/locations"
            local url = "https://api.smart.gardena.dev/v2/locations"
            self:trace("Getting locations")
             http:request(url, {
                options = {
                    method = "GET",
                    headers = {
                        ["Accept"] = "application/vnd.api+json",
                        ["X-Api-Key"] = self.client_secret,
                        ["Authorization"] = "Bearer ".."Token"
                    if response.status == 429 then
                        self:debug("Too many requests")
                        return
                    elseif response.status == 200 then
                        self:trace("Request OK")
                        if #data.data > 0 then
                                self.location_id = data.data[1].id
                                self:trace(string.format("Location_id: %s",self.location_id))
                        else self:error("Location missing - user has not setup system")
                end,
                    self:debug("Location HTTP error:", message)
            else
            self:debug("Location Already OK")
