I dont even know if this is joke or real :D You dont update app too often and it is really bad if basic functions are broken.
Including new device - worked, great...
Renaming it, moving it to other room, changing icon... all ends up by "something went wrong... This does not seems like "ui improvements"... Is anyone at all testing this?
Any specific device that causes this? Could you provide some details?
With that kind of generic feedback may be hard to reproduce and then, fix it.
Hub version will help a lot here.
I also have the same problem. When i try to edit the device (any editing, change name, icon etc), when i press save at the end it shows that something went wrong.
I tried to change setting on the fibaro smart implant and fibaro single switch. Both same issue.
Home center: Yubii  Home
HC version: 5.161.15 (beta)
Phone: Xiaomi 11T
App version: Yubii Home 2.2.0
Edited by JureZ
