Block scene is not using time period "from:to"
I am trying to create the sample scene that will be depending on time period (for example running only from 9:00 till 17:00).
I have added the rule "All should be true" and put the time period 9:00 - 17:00 as one of the factor with "&" between next factors.
Bot now when I am running the scene it does not depend on time at all. For example scene presented on the screenshot run at 18:00 is switching off the light, but it should be posssible to run from 9:till 00  17:00 only.
How can I solve this?
Edited by Confiable
mistake
If you run the scene manually, you override the conditions. You just tell it to run, and it does so.
(And I don’t see a trigger in your conditions, so it won’t run by itself, but maybe you didn’t show all of the blockscene)
    Hello @SmartHomeEddy
    I attach the screenshot from the whole scene.
    I wanted to use this scene as the subscene from other one.
    When that other scene runs (invoked manually) - the subscene is always switching the light off, without paying attention to time described.
    Is there a way to pay attention to time described in such situation?
    Thanks @Confiable
    I can't really read what is does, English would be nice, and I don't see any trigger. So the scene doesn't get an impuls to do something.
    I don't understand why you should run an other scene manually. A scene is meant to run by itself. And why use more scenes.
    But maybe first explain what you want to achieve.
