Fibaro roller shutter hitting another fibaro roller shutter wirelessly
Hi guys,
we have a client who has fibaro roller shutters connected to their blinds, we are wondering if there is any way to trigger this relay with another relay connected to a switch on the wall.
We don't have the option of running a cable between the switch on the wall to the relay connected to the blinds.
the client uses HC3 but we want a manual option
Cheers
you can use another fibaro roller shutter behind the switch and then use "Assocations" (in the settings) between these two. (Association (linking devices) - allows for direct transfer of control commands between Z-Wave network devices. Main controller does not take part in such communication. Using this mechanism, devices may communicate with each other even when the main controller is disabled or damaged, e.g. in a fire.)
