11thNun-Facilities 1
Hi all, I am in need of some advice. We have two thermostats controlling 2 climate zones and have set a heat schedule for each. I assumed I could just use profiles to switch between heating on/off and created a winter and summer profile for this. As per the image, the winter schedule has the profile set to Schedule and the summer one is set to manual - off. I expected switching profiles would just turn the heating to be either on as per the schedule or manually off held. What is happening is the profile change seems to set the change as a manual overdue for 2 hours. I can see this because there is a time remaining showing against the device. Have I missed something here? The only way I can get it to work is by creating a scene to switch the heating on called by the profile and removing the climate setting from the profile. Image 2. In the scene I turn the heating on to schedule and the after a 1 minute delay send a signal to cancel any manual override setting. I shouldn’t need to do this.
