chummmer 0
hello folks,
I managed to implement a shelly plug S (wifi version) over quickapp to my HC3 LITE... so far so good, I was hoping to get energy readings (in my case its about produced energy from my PV-panel), but its not showing in fibaro home center. its definitely working, since I get readings in the shelly app.
BTW, I used to work with the ABUS plug, which worked quite okayish - showed produced energy as consumption, but better than nothing - but it went offline some time ago and didnt recover. My contact to fibaro support told me to implement the QUBINO SMART METER instead, but this would need to be installed by an electrician. I have an AEOTEC Energy Meter (3 phases) available as well, but I dont think its (fully) supported either - experiences anyone?
however, does anyone have an idea how to make this setup with the shelly plug S work (with energy readings from the plug in home center) - maybe by changing some variables? is there any documentation for that?
thanks in advance,
alex
