RS4 generate 100% CPU usage on HCL3
Hi
I have added RS4 to my ZWAVE Network (HCL3 + several roller shutter from 221 to 224, switch relays,...= 21 devices)
When I open/close the blind with RS4 via Apps or wall Switch The CPU usage is 100% uiring 2 min and HCL3 is not responding to any request from RS4 and  other devices
Does RS4 compatible with HCL3? What is the RS4 configuration with HCL3
In general, RS4 is fully supported.
Its strange, please contact support - they will investigate. I don't think it is RS4 related.
    I have swapped with an other RS4 same issue with the new one. HCL3 and zwave network works fine when the RS4 is unplugged
    @tetsuo do you solved this? I woult to integrate 3 roller shutter 4 at my HC3L. Thanks.
