T5B 0
I have a HC3L (Home Center 3 Lite) that used to work great, I have recently upgraded/updated to the new YubiiHome.app for iOS (previously I've used the 'old' Yubii.app for iOS) and that works great, but since I found the web-interface easier to set complex things I had also setup the interface on macOS, by directing my browser to xxx.xxx.xxx.xxx/app/dashboard
in which xxx.xxx.xxx.xxx is the IP-address of my HC3L
that used to work great, but now I can no longer connect to xxx.xxx.xxx.xxx
I've double-checked, and according to the YubiiHome.app for iOS I am using the right IP-address
And my network-scanner.app does detect the HC3L on that same xxx.xxx.xxx.xxx IP-address
But the FibaroFinder.app for macOS (which is quite a hassle to install in new versions of macOS) does not detect any Fibaro device on my network... so I cant get to the web-interface that way either...
Am I doing something wrong ? If so, what ?
Is there a new Yubii Home web-interface or an app for macOS that I should use ?
Or is it no longer possible to use a web-interface to control my HC3L ?
