Madmykel 0
Hello Helpers.
I don't know anything in Lua but I create a Alarm configuration in Fibaro HC2, actually 2 motion sensors as test.
I also create a Fibaro scene to arm/disarm the system from a key from the keyfob Fibaro, to test it. It send me notification to arm or disarm.
Arming system is ok, notification is sent and I can see Fibaro arming my 3 motions sensors.
Disarming do not work from keyfob, but ok if I use my smarphone, as It need a pincode, seem mandatory whent activating Alarm pannel in Fibaro.
My question: Is it possible to disarm the system only using a pressed key on a device (Fibaro Fobkey) ?
(I know it less secure, but actually it not my scope).
Thank you for your help
