Roll Shutter 3 with eWickler W820
Hello Friends,
Which shutter do I need for this model?
eWinder eW820 ?
Technical data
 Flush-mounted use
 Supply voltage 230 V ~ 50 Hz
 Nominal power (maximum) 120 W
 Standby consumption ≤ 0.2 W
 Nominal torque 11 Nm
 Nominal speed 32 rpm, regulated
 Pulling power (maximum) 50 kg
 Belt width 23 mm (eW820) / 15 mm (eW820-M)
 Winding capacity 6.3 m (1 mm strap thickness)
 Permissible roller shutter area approx. 7 sqm at 5 kg/sqm, approx. 4 sqm at 10 kg/sqm
 Short-time operation 4 minutes
 Overtravel < 0.2 U
 Protection class II
 Protection class IP20
 Power reserve (in case of power failure) approx. 20 h
 Housing dimensions 132 x 139 x 34.5 (H/D/W)
 Mounting hole spacing 165 / 185 mm
 Temperature range +4 °C to +40 °
Translated with DeepL.com (free version)
eWinder eW820 ?
If by this you mean what kind of blind to buy, then one that is pulled up using a belt that is wound on a reel.
If you are asking if you can use RS2/3/4 to control this product, then none of the RS versions can be used!
What you have is a closed, self-functioning product, without the possibility of a wired connection to control the direction of movement of the blind.
