Hello, also in this version multi select is not working properly in all views and app, i.e. local and cloud web GUI, faceplate, development pages, namely HC3 or HC3L.
In some places multi select can't be set at all, in other places multi select can't be set.
Please, check all.
If you could elaborate a bit with some details it will be helpfull, you can also just answer the questions below :)
1. Multiselects on device control views (mobile app and hub) in legacy solution?
2. Multiselects on device control views (mobile app and hub) in new solution?
3. Multilselects in device configuration (like category selection)?
4. Multilselects in group actions in the scenes?
5. Multiselects inside QuickApp editor in preview mode?
PS
Lack of correct handling multiselects in new device control views in app is currently a known issue
    Hi @m.roszak, please check this.
    Multi select check
        HC3
    View Access generic type QA html view generic type QA ui view custom child view
    development view local OK OK na
    development view cloud OK OK na
    devices list view local OK OK OK
    devices list view cloud OK OK OK
    faceplate view local OK OK OK
    faceplate view cloud OK OK OK
    YUBII Home native Android app na OK na OK
    YUBII Home new Android app  na OK error-only single select error-only single select
    Thanks, so it is directly related with a known issue I mentioned, that the new app does not support correctly multiselect.
    It is not related with hub firmware in any way. It is planned to be fixed in one of upcoming app versions.
    I was really worried that we broke something in this beta.
    Hi @m.roszak, thats great :-)
    If I can find the time, I will test everything on HC3L as well. Last week there were still differences between the display and functions on remote connection for HC3 and HC3L, where the same operation did not work correctly on HC3L.
    In any case I found one bug, and that is updating the values of selects on the faceplate web GUI. All other objects update their values immediately even when the faceplate device is displayed, but the select does not.
    So if I use code to change the options in the select while the faceplate web GUI is open, the options are not updated and I have to close the faceplate and when I reopen it, the options are already populated correctly.
    This is very annoying e.g. when using cascading selects, where the first select filters the options for the second etc. I now use for cascading selections of sections/rooms/facilities. Unfortunately now after each selection the faceplate has to be closed and reopened.
    Thanks for the fix :-)
