Hi, I need some help with a simple syntax for the eventrunner. I did set up this long time ago and it has been working flawless ever since.
The scenario is following. I have a Fibaro Dimmer. Option 28 i set to 1 and I would like to toggle a binary switch when S1 is pressed once. According to the manual this should be SceneID:16 on a momentary switch. The device is named : LYS_CTRL (using hometable).
I created this rule:
rule("SOVEROM1.LYS_CTRL:value == '16' => SOVEROM1.SENSOR:toggle")          -- Toggle sensor on 1x push
This is the error
[18.10.2024] [18:42:25] [ERROR] [QUICKAPP415]: [Rule:15:SOVEROM1.LYS_CTRL:value == '16' => SOVEROM1.SENSOR:toggle] Rule: No devices found for :value, must be defined when rule is defined
Any help with the syntax would be appreciated :).
Please ask questions about EventRunner in the "EventRunner 5" forum thread.
Anyway, it complains that
SOVEROM1.LYS_CTRL
is not defined in your home table (its value is nil). Have you checked the spelling?
    Ok, thx. I'll post my next question about Eventrunner in correct forum. Thank you for replying. I'm using something wrong statements in the rule.
    Rule used:
    This is the message I get:
    [19.10.2024] [01:14:52] [TRACE] [QUICKAPP415]: [Rule:16:2]>> FALSE #device{id=444,val.. -> SOVEROM1.LYS_CTRL:scene == '16' => {SO..
    This is a working code I'm trying to replace:
    Rule used:
    But you should use :scene
    Like,
    and use integer 16 to compare against, not string '16'.
    Thank you, worked flawless :)!
