F.Surman 0
Good morning,
i have a problem adding Qubino to both HC3 and HC3l with the latest version of Fibaro FW 5.160.42. After adding, it appears as a light dimmer, but the temperature sensor is not loaded, see photo.
We have this build:
- Qubino Flush Dimmer 0-10V Plus [ZMNHVD1]
- Qubino Temperature Sensor ZMNHEA1
- HC3 and HC3l with the latest version of Fibaro FW 5.160.42
The temperature sensor is correctly connected, see photo. Same assembly connected to HC3l with older FW and temperature sensor initialization without problem. So we suspect that there is an error in the new Fibaro FW.
Edit: Now I tried adding the device on the old FW (OK) -> Then update Fibaro FW ->The device works and reads values correctly.
So this is a problem of adding the Qubino Flush Dimmer 0-10V device on the new FW. Is anyone having the same problem please? Thank you.
Tested multiple Qubins, temperature sensors and HC3 and HC3l units.
6 answers to this question
